heat soak?
i have a 2001.5 s4 and for some reason after i drive around for a bit then turn my car off to go into a store or something for a few minutes when i come back out my temp is quit a bit past center. what are somethings i should look for? and is that normal, its been about 104 degrees around here lately in az. i figured it was just heat soak because after driving for a minute or so it will go back to center.
it does sound like heat soak to me in that heat you probably could boil an egg on the hood lol, a new thermostat and coolant might be a good idea but it doesn't sound as if you have an issue unless you cant get heat into the car ( that might sound silly but you should turn the heat on at least once per month to keep the system functioning ) other wise valves in the heating systems lock up
the water pump and timing belt were changed 12k mi ago. i think the coolant is fresh. and for some reason the car slowly loses water, so it has me a tad worried. about a quart every 4k or so. also where would the thermo be located and how abouts do i go flushing the cooling system if i were to do it. Also, where can i go to get a book on how to work on this car haha. dealer?
