heat soak?
Old May 19, 2006 | 07:32 AM
skyline44_2001's Avatar
Default heat soak?
i have a 2001.5 s4 and for some reason after i drive around for a bit then turn my car off to go into a store or something for a few minutes when i come back out my temp is quit a bit past center. what are somethings i should look for? and is that normal, its been about 104 degrees around here lately in az. i figured it was just heat soak because after driving for a minute or so it will go back to center.
Old May 19, 2006 | 11:37 AM
techbod's Avatar
Default RE: heat soak?
it does sound like heat soak to me in that heat you probably could boil an egg on the hood lol, a new thermostat and coolant might be a good idea but it doesn't sound as if you have an issue unless you cant get heat into the car ( that might sound silly but you should turn the heat on at least once per month to keep the system functioning ) other wise valves in the heating systems lock up
Old May 19, 2006 | 12:20 PM
the water pump and timing belt were changed 12k mi ago. i think the coolant is fresh. and for some reason the car slowly loses water, so it has me a tad worried. about a quart every 4k or so. also where would the thermo be located and how abouts do i go flushing the cooling system if i were to do it. Also, where can i go to get a book on how to work on this car haha. dealer?
Old May 19, 2006 | 12:23 PM
techbod's Avatar
Haynes manual is cheap and shows you where and how
Old May 19, 2006 | 12:27 PM
techbod's Avatar
for the coolant lose check all the hose clamps are tight but you can expect to use more coolant in those temps
JasonDillard
Dec 24, 2017 02:26 PM
Msnickbroderick
Jun 11, 2010 02:06 AM
ahbrit
May 25, 2007 12:38 PM
StepUpProductions
Nov 9, 2006 08:35 PM
holden
Aug 19, 2005 02:37 AM
