heater coil or climate control issue?
Old Oct 12, 2009 | 12:50 AM
josh_easlon's Avatar
Default heater coil or climate control issue?
been having some issues with my heating. i will run the climate control to "hi" after the car is warmed up, it will run warm for a little bit and start to cool down after a couple minutes. turn off the climate control, wait 5 minutes and its hot again, only for a few minutes, then it gets luke warm. anybody have issues like this before and have any insightful recommendations? its starting to get cold here, and i would appreciate any help! thanks!
Old Oct 12, 2009 | 10:50 AM
drobrt's Avatar
Sorry man, I don't have a solution for you. I have been fighting this same issue for the past 2 winters. The closest I could get was when I pumped out the coolant tubes runnning into the cabin. I used a chemical to try and break down debris that may have come off the heater core. That seemed to work for a few weeks but after that it was back to normal (no heat). But I am determined to remove my entire dash soon and replace the heater core. I'm thinking that might be my issue, hopefully. I know that this has happened with a lot of B5 owners.
Old Oct 12, 2009 | 04:14 PM
drev500@aol.com's Avatar
sounds like your heater core is pluged up. Take it to a rad. shop that can boil out the whole system and that should fix it for both of you.
Old Oct 12, 2009 | 09:34 PM
thanks for the help! winters creeping up fast here, best i get it done asap.
drobrt, i'll let you know the outcome of taking it to a rad. shop. thanks!
Old Oct 13, 2009 | 03:23 PM
drobrt's Avatar
Alright great! Thanks.
Old Oct 13, 2009 | 09:06 PM
No problem.
chris11104
Apr 13, 2014 05:20 PM
chrislaw_12
Dec 4, 2013 10:30 AM
jrj289
May 27, 2013 11:36 PM
o-one-a4
Sep 28, 2011 04:03 PM
68jcode
Nov 22, 2008 09:47 AM
