Help Codes 1128,1130,1137, 1139
Old Feb 4, 2008 | 08:11 PM
jwehrheim's Avatar
Default Help Codes 1128,1130,1137, 1139
I am posting this here because the S4 guys have the same motor. I have a 2001 A6 2.7T. 6 speed. Only 60,000 miles.
I have all 4 codes 1128,1130,1137, 1139. In looking up the codes it says the Fuel Air Metering is Lean and Rich.
What is causing these codes. MAF and or Oxygen Sensors or something else.
Thanks for the help
Old Feb 6, 2008 | 12:00 AM
dankhound's Avatar
Default RE: Help Codes 1128,1130,1137, 1139
Lean and rich is most always a maf.
Old Feb 6, 2008 | 12:13 AM
Blue_S4's Avatar
much of the time its the o2s...i think more than the MAF, which has nothing to do with lean or rich cuz it has no relation to the fuel. The O2s measure the amount of fuel thats not being burned (by measuring, you guessed it, o2 levels in the exhaust gases), and adjust the fuel flow accordingly. however...you cannot really have lean and rich at the same time
lean is not enough fuel, rich is too much fuel....that doesnt make sense to be able to have both...its one or the other.
check the O2s first...either that or possibly your cats.
Old Feb 6, 2008 | 03:50 PM
jwehrheim's Avatar
I was hoping it was not the O2 Sensors. Isn't there 4 of these? Is there a way to check them or just replace all 4. Any suggestions on a low cost supply of these?
Thanks for your help!!
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
jhsoccerodp
Sep 22, 2008 07:54 PM
jwehrheim
Feb 4, 2008 08:36 PM
upgraders
Nov 30, 2006 01:09 AM
