Help me with this s4
ORIGINAL: stunnuh
Any one out there that woks on audi's or knows anything besides hey you should sell it.
All right now we are geting some where, this car looks so good in the garage but I am dieing to drive it, sorry if I seem short want to drive this car bad.
I have ordered theballast or that small metal box that mounts on the lights , you say the central unit is out and I should get a new one, I hear tons of electrical stuff runs threw this box, I know it was siting in water, thanks so far
i say do to this web site ecs tunning and get most of your parts there little cheaper then the dealership. yeah as for most of the electrical if it was jsut water no silt (that is the mud in the water) you might be ok when it dried out. but the silt will coat everything and and short it out. you need to do a ground up from removing the carpets and seats and cleaning them. http://www.popularmechanics.com/how_...e/1272386.html . That was just a quick search on google, not the best help but kind of helps. and also put it this way how much did you get the car for? and how much would it be worth if it worked at a dealership, some where in the middle is the number it will take to fix the car. i say take it to audi get them to tell you EVERYTHING that is wrong with it might be 200 dollar job might be more. but at least then you know what you have to do. but this is just my two cents. let me know if you need any more help.
ORIGINAL: stunnuh
Hi ! hope I am not naging you but you said I need the central unit (black box) I just don't want to order things that don't help,man I hope this fix's some electrical stuff thanks.
ok the ballast are in, when you turn on the lights with the key in the on position the lights work fine. if the key is in the off position the lights storbe. the dealer can't seem to find a central control unit that part i need any help would be greatly apperciated.
WOULD LIKE TO HAVE A SET OF NEW HEADLIGHTS if i don't have to pay 2,000.00 any hints
Yeah here's a hint Buy a new cheap *** set and see if it does the same thing. HID's aren't your problem right now, LIke what 2ks4 said you need to find someone in the area to help you with or you buy a Vag com and check the codes. As for having Downpipes your gonna throw CEL's anyway and you can fix that but that may not be the only problem with your sensors. Also, Did your black box get wet? If so, even the littleist amount of water and mildew, dust, dirt, etc can cause major failure with electronics. FYI I gotta say good luck but you might be better off getting rid of it or turning it into a parts car. Or Find a parts car and start ripping things apart and replacing shyt. ANyway Dude, good luck!!
