horsepower ques.
Old Feb 24, 2008 | 05:38 PM
popsinc's Avatar
Default horsepower ques.
who knows where the S5 got their 14 extra hp from? My 2005 has the same 4.2 but I'm rated at 340 hp. S5 has 354. Any ideas???
Old Feb 24, 2008 | 05:41 PM
shawncumberland's Avatar
Default RE: horsepower ques.
If Audi is anything like GM, it is just underrated in general, a few HP here and there... 340 HP may be better from an insurance standpoint of being under 350 HP.
Shawn
Old Feb 24, 2008 | 05:43 PM
popsinc's Avatar
Thats true. Thanks! Any ideas on my brake ques while were talking?
Old Feb 24, 2008 | 06:00 PM
SourDieselS4's Avatar
S5 is the beginning of a new model and the new b8 platform which will be shared with the new A4/S4. The main reason for the increase in power is FSI which is on the s5 but not the s4 v8's
Old Feb 24, 2008 | 06:04 PM
Blue_S4's Avatar
actually, im going to disagree....while the FSI can improve HP, not 14 more in an already uber-efficient motor. The FSI will help efficiency more in this engine. The gain is going to be in the higher flow exhaust the S5 has, as well as in the better air intake system they can incorporate from the larger engine bay.
Old Feb 24, 2008 | 06:15 PM
Im sure thats a factor too. This is form the the audi s5 website info.
FSIĀ® direct injection technology increases the torque and power of spark-ignition engines, makes them as much as 15 percent more economical and reduces exhaust emissions. In contrast to conventional intake manifold injection on conventional spark-ignition engines, FSIĀ® engines inject fuel directly into the combustion chambers. This technology dispenses with the throttle plate. That ā€˜unthrottles’ the engine, reduces heat loss and thus increases output while reducing fuel consumption.
The system uses two charge-air supply modes: stratified charge at partial load and homogeneous operation at full load. In the stratified charge mode, an combustible fuel-air mixture is only produced in a defined zone around the spark plug. The engine management electronics monitor engine load and adjust injection timing, pressure, quantity parameters as well as the air flow inside the cylinder via the air intake channel.
At full load, FSIĀ® increases compression as well as engine efficiency and performance.[
I just feel that audis justification for increasing the HP rating on the same motor would be the addition of the FSI system. FSI is used in the RS4 and R8 v8's too
ChadS89
Apr 11, 2008 01:11 AM
nemiz
Sep 26, 2007 04:49 PM
soccerplayer01
Jul 9, 2007 04:41 PM
ChristopherPovey
Mar 20, 2006 02:42 AM
2khb
Jul 30, 2005 08:43 PM
