how do i fix this!?!
Old May 19, 2009 | 01:37 AM
bottlecap's Avatar
Default how do i fix this!?!
its been like this ever since i did my clear corner delete mod...i also put in new 6000k bulbs..did i install them upside down or something? i heard something about vag-com needed in order to readjust it but that seems stupid and if true makes me not like audi. the driver side is just fine, the passenger however is waayyyy to low as you can see in the picture.
Old May 19, 2009 | 10:42 AM
drev500@aol.com's Avatar
i think there is manual adjustment tab that is white plastic behind the housing. Just use a philips screw driver and turn it
Old May 19, 2009 | 08:27 PM
bottlecap's Avatar
tried that, it didnt move the light at all. im wondering if something is broken
Old May 19, 2009 | 11:19 PM
drobrt's Avatar
Mine does the same thing. the right hand side is lower and points off to the side more. Maybe there is something to do with the way I installed the bulbs. But then my headlight housing adjustment might be broken too.
Old May 20, 2009 | 12:02 AM
its plastic, what do you expect?
Old May 20, 2009 | 01:47 AM
bottlecap's Avatar
this is true. for such an expensive car, they did cheap out a lot on plastic headlights
Old May 20, 2009 | 01:07 PM
drobrt's Avatar
True, but its an Audi. Not a Chevy.
Old May 20, 2009 | 04:10 PM
mys4.org's Avatar
There is two white plastic ***** per headlight. Did you try both?
Old May 20, 2009 | 05:14 PM
bottlecap's Avatar
yea one was for the highbeams and the other the projector
Old May 21, 2009 | 07:11 PM
one4eyes's Avatar
Member
i think one is for left and right adjustment(the one at the fender hole...i think).....the other for up and down adjusment....you have to turn it alots for it to even start moving
