Leaking coolant
Old May 23, 2008 | 12:56 PM
kiellish's Avatar
Member
Default Leaking coolant
My 2000 s4 is leaking coolant from somewhere behind the engine but I can't see where it's coming from. Is there a common part that begins to leak back there? The reservoir will empty sometimes in as quickly as a few hours, other times it will take days.
Old May 23, 2008 | 01:45 PM
Reiem125's Avatar
Default RE: Leaking coolant
I had the what sounds like the same leak you do and it turned out to be my auxillary water pump. I'd say check that out.
Old May 23, 2008 | 02:35 PM
kiellish's Avatar
Member
Where is that located and how hard is it to change?
Old May 23, 2008 | 04:16 PM
Reiem125's Avatar
It's not fun but here is a write up i found. I hope this helps good luck.
http://forums.audiworld.com/s4/msgs/1585786.phtml
TD2005
Nov 3, 2014 03:41 PM
adam044
Feb 16, 2014 05:52 PM
suni
Mar 9, 2009 08:53 AM
CiaranMc
Jun 25, 2008 03:34 PM
Bryceaudi
Jul 31, 2007 03:42 AM
