looking at a 2002 s4
Old May 11, 2008 | 04:53 PM
02AudiS4's Avatar
Default looking at a 2002 s4
Hey i am looking to buy a 2002 Audi s4 with semi auto transmission for about 9,000 dollars. i am also looking to spend another 5000 on the car what upgrades should i get . i want to get a (bov valve,milteck echuast,cold air intake)
Old May 11, 2008 | 05:12 PM
Blue_S4's Avatar
Default RE: looking at a 2002 s4
use this....
https://www.audiforums.com/search.asp
Old May 11, 2008 | 09:41 PM
sweeds4's Avatar
our cars don't use vbov's and cold ait intakes don't benefit. still with stock airbox or do the 'darintake' mod which is basicallt drilling holes in the airbox. seach for it.
5000 can get you turbo's and fueling. but yiu would need about 1500- 2000 for labor for the install plus all the little stuff that needs to be replaced if u need a shop to install it for you. that requires the engine to be pulled or if they know how to do it without pulling the engine better for you. with that power yr tc might have some problems.
or for 5000 you couls get a chip, turboback, suspension, bbk and wheels. less money but lookin niiice!
goodluck and the search is yr friend!
Old May 11, 2008 | 09:47 PM
trapped's Avatar
BOV's wont help, the 2.7t uses Diverter Valves to recirculate the air. 710n DV's from the TT work great. Forge 007 valves work great as well. Baileys are also good, but I have only used 710n's
Old May 12, 2008 | 04:15 PM
02AudiS4's Avatar
ooh thanks
Old May 12, 2008 | 04:20 PM
02AudiS4's Avatar
Evolution Motorsports 2.7T V-Flow Intake
$299.00
Forge Motorsport Type RS Valve - Recirculating
- Color: Anodized Black
- Connector Size: 34mm Connector
$220.00
Milltek B5 S4 2.7T 3" (76mm) Catback Exhaust System
$1,149.00
Subtotal:
$1,668.00
Old May 12, 2008 | 04:23 PM
godowninflames's Avatar
FYI. you need 2 Diverter Valves.
Old May 12, 2008 | 05:02 PM
02AudiS4's Avatar
really 2 for that car, ****, i wonder how loud its going to sound when i let go of the gas or shift in the other gears. Also how do u install the divertor valves
Old May 12, 2008 | 07:04 PM
readimag's Avatar
you that search function for go there, www.audidiy.com
Old May 12, 2008 | 08:13 PM
02AvantImola's Avatar
You will barely hear anything when you shift.. If you read the forum at the top that mentions BOV, a lot of your questions will be answered.
