Lowering on 19's
Old Aug 10, 2008 | 11:28 AM
Ryan2008's Avatar
Default Lowering on 19's
How far can you lower the b5 with 19 inch rims on it?
Old Aug 10, 2008 | 05:53 PM
drev500@aol.com's Avatar
haha not far at all with out rollling of the fender
Old Aug 10, 2008 | 06:51 PM
SourDieselS4's Avatar
That has little to do with it. When you get 19" wheels you make the sidewall profile smaller so the actual outer diameter, and rolling distance of the tire is within 1 or 2% of what it was from the factory. Otherwise your speedo would be off by a stupid ammount. The issue with rubbing is lowering the car with wider tires, or a different offsett. Lots of people are lowered on 19" wheels its just a whole lot easier to bend a wheel, logic would say they are heavyer, and ride quality is decreased alot. If you dont wanna rub dont go wider than 235mm and stick to an offsett like 35mm. Im running 18x8.5 with 235/40/R18 and a 35mm offsett and i have minimal rubbing.
Bigger wheel, less sidewall. The outer diameter should be as close to stock as is possible.
Bottom line, get coilovers so you can adjust it how you want. You can lower the car just as much as you could with 18" or 17" wheels. The narrower the tire the lower you can go.
djnick
Dec 12, 2009 11:07 PM
mikeeace
Dec 1, 2009 12:02 PM
petes4
Mar 9, 2008 08:51 PM
100mhz
Jun 21, 2007 12:57 PM
mark80scu
Apr 13, 2007 08:07 PM
