my brakesss
Old Aug 8, 2007 | 04:08 PM
ARIaudiS4's Avatar
Default my brakesss
alright well i installed new ECS rotors and hawk hps brakes yesterday. everything was rollin good, but then my car just started to loose power today. I noticed that the pads are rubbing against the rotors. How can i fix this problem.. what could be the probleem?
Old Aug 8, 2007 | 08:52 PM
2k S4's Avatar
Default RE: my brakesss
Front or rear? Do they just rub, or are they slowing down the car with out you hitting the pedal?
Did you bed them in? Did you change the fluid? Did you push the caliper pistons all the way back in?
Old Aug 8, 2007 | 11:17 PM
ARIaudiS4's Avatar
front, looks like the rub, but BARELY slow the car down. like in neutral the car will roll back. bed them in? i did not change the fluid, yeah when i removed the old pads i pushed the piston all the way back in...
Old Aug 9, 2007 | 10:23 AM
2k S4's Avatar
Yea, you got to bed new pads in. What you do is, do a several hard stops from 60+. You want to get the pads nice & hot, then drive around to cool them off.
Old Aug 9, 2007 | 11:56 AM
GeilKyle2's Avatar
If the car will roll under it's own weight, the brakes are not dragging.
