My overheating saga - Fan Clutch Behavior?
Old Jul 29, 2007 | 10:52 AM
carhopper's Avatar
Default My overheating saga - Fan Clutch Behavior?
I've been having an overheating problem at idle for some time. It's never actually overheated because I watch it closely, but here are the symptoms. When I idle for more than 10 minutes or so with the AC running it climbs to over 1 tick past middle. Tstat is new along with water pump. I just replaced the coolant tank yesterday due to a crack, but only marginal results in the problem. Here is my latest finding. While idling, I can hold back the fan clutch with my pinky as there is no resistance. Is this normal or have I found my problem?
Old Jul 29, 2007 | 03:49 PM
mattbracing's Avatar
Default RE: My overheating saga - Fan Clutch Behavior?
Your fan clutch is gone i haid the same thing happen they are not to pricey
Old Jul 29, 2007 | 10:07 PM
carhopper's Avatar
They're about $100 aftermarket. I don't know about the dealer. You say your car was doing the same thing? Can you confirm that your new clutch had different behavior? Thanks, I just want to be sure.
Old Jul 29, 2007 | 10:09 PM
2k S4's Avatar
The fan is toast, get a new one.
Bleed your coolant system, you should not be overheating at all. The new thermostat might be sticking.
Old Aug 4, 2007 | 10:19 AM
carhopper's Avatar
Well, I thought the fan clutch fixed the problem but it didn't. It helped, but still not completely fixed. I don't know what's left. I can't get the bleeder plug out because it's stripped and impossible to get a pair of vice grips on. I think it must be the thermostat. It's a bit intermittent too.
GCMARK
Dec 7, 2011 10:01 AM
XxVladxX
Apr 15, 2009 11:27 AM
zippy_gg
Apr 3, 2009 04:38 PM
zippy_gg
Apr 3, 2009 03:14 PM
Yuikio
Dec 21, 2008 09:59 AM
