need some help very strange problem
Hopefully someone can help me out. I amdealing witha problem I never seen before. I currently am working on a 01.5 S4 (6 speed with ESP), my problem is for some reason the cluster is not communicating with the abs controller. There's an abs light on along with the brake light and to make things even more strange the rpm on the cluster does not work. If I go into instruments with the vag and go to adaptations group 60 and change the code from 1025 (esp) to 0 (non esp) the rpm signal on the cluster works!! The carcame with a"T" box ecu from the factory. It nowhas a chipped "M" box in it. According to the vag the cluster and ecu are seeing one another but no communication from the cluster to the abs or from the ecu to the abs. I even tried switching clusters, abs control module and abs controller, still same outcome. I checked the wiring of the can bus from the ecu to cluster to abs and everything seems fine. The ecu is coded for esp as well, If anyone can help I would really be grateful. Below is a copy of the auto scan. Again any input would be appreciated.[/align][/align]VAG-COM Version: Release 704.1
Data version: 20070723
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 8D0 907 551 M
Component: 2.7l V6/5VT G 0002
Coding: 06711
Shop #: WSC 63351
2 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
18031 - Powertrain Data Bus: No Communication
P1623 - 35-00 - -
Address 08: Auto HVAC Labels: None
Part No: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D58
Coding: 00001
Shop #: WSC 00000
5 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
01087 - Basic Setting Not Performed
35-00 - -
01044 - Control Module Incorrectly Coded
35-00 - -
Address 15: Airbags Labels: 8D0-959-655-AI8.LBL
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 63251
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8D0-920-xxx-17.LBL
Part No: 8D0 920 981 B
Component: B5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 05127
1 Fault Found:
01312 - Powertrain Data Bus
37-00 - Faulty
Address 35: Centr. Locks Labels: 8L0-862-257.LBL
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 63251
5 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63251
2 Faults Found:
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor; Front Right
35-00 - -
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 63251
No fault code found.
End --------------------------------------------------------------------------------------------------
--------------------------------------------------------------------------------------------------------[/align]
Coding: 06711
Shop #: WSC 63351
2 Faults Found:
P1649 - 35-00 - -
P1650 - 35-00 - -
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
P1623 - 35-00 - -
Coding: 00001
Shop #: WSC 00000
5 Faults Found:
35-00 - -
35-00 - -
Coding: 00304
Shop #: WSC 63251
1 Fault Found:
Coding: 02264
Shop #: WSC 05127
1 Fault Found:
37-00 - Faulty
Coding: 16140
Shop #: WSC 63251
5 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00101
Shop #: WSC 63251
2 Faults Found:
35-00 - -
35-00 - -
Coding: 00110
Shop #: WSC 63251
