OIL IN MY Y PIPE .IS IT OK
Old Mar 3, 2008 | 07:31 PM
loves4's Avatar
Default OIL IN MY Y PIPE .IS IT OK
OIL IN MY Y PIPE IS IT OK .I WAS TESTING MY CAR FOR BOOST LEAKS SAW THAT I HAVE OIL IN MY Y PIPE. THEN I TURN UP MY COMPREST AIR TO 17-18 PSI AND MY LEFT DIVERTER VALVE WAS PORING AIR IN TO MY INTAKE .IS IT OK OR NOT, BECAUSE I HAVE APR CHIP SO ITS LIKE 17 PSI ..HELP .
Old Mar 3, 2008 | 07:47 PM
shawncumberland's Avatar
Default RE: OIL IN MY Y PIPE .IS IT OK
NO NEED FOR THECAPS ON EVERY FREAKN WORD.
a little oil is normal, if it is dripping oil, or more than a misting, or if the intercoolers areoil soaked on the inside... your in trouble.
well, at least I wouldn't be thrilled about it.
Shawn
Old Mar 3, 2008 | 08:01 PM
loves4's Avatar
what would be a problem . ?
Old Mar 3, 2008 | 10:42 PM
drev500@aol.com's Avatar
your left diverter is shot buyforge diverters (or something comparable)since your probably running stock.
Old Mar 4, 2008 | 06:35 PM
loves4's Avatar
no i got turbo smart diverter valves they just like forge. they got springs inside of them .
Old Mar 4, 2008 | 07:05 PM
timtheguru's Avatar
I also have my oil in my pipes, but only appears on the drivers side... I need to check the intercooler soon.
Old Mar 5, 2008 | 04:23 PM
2k S4's Avatar
Some is normal. You need to rebuild your DV's. You test them with vacuum, not boost.
There is a PVC type valve that attaches to the Y pipe, it might need to be replaced.
xb6boix
Apr 17, 2012 09:39 PM
mizzike2555
Apr 23, 2008 05:05 AM
Hanestyle
Oct 24, 2006 04:07 AM
Mythstery
Jan 19, 2006 08:17 PM
greenday
Nov 29, 2005 03:43 PM
