overheating
Old Nov 28, 2007 | 01:41 PM
audis4v6biturbo's Avatar
Default RE: overheating
I am not necessarily experiencing the same problem, however it is kind of similar. I have a 2000 S4, stock except for Borla pipes, and I notice that my coolant is low in the resevoir. I had driven the car for 11 hours straight and didn't notice until i stopped to check to check the oil level. The engine temp never moved from cold for the entire trip and it was 70-75 degrees that particular day. Any comments? Also can I put any type of red coolant in the resevoir? Thanks, I appreciate any help.
Old Nov 28, 2007 | 02:12 PM
2k S4's Avatar
ORIGINAL: audis4v6biturbo
You have a bad thermostat, & possibly a leak. Check the afterrun pump & coolant tank, they are most common leak points.
Old Nov 30, 2007 | 12:49 AM
Hey thanks alot man, I appreciate it. Do you think thatI can make another 10 hour trip if i continue to maintain an eye on the coolant level where it is, it is approx. an inch above min.(it would be in 25-30 degree weather)? I know that there is coolant already stored within the engine, andI have heard stories of guys who have filled above min. and experienced an overflow when the system starts to circulate. That is why I am apprehensive to fill the coolant level much higher. Any thoughts? Also should Ibe able to add any sort of red coolant/antifreeze or should it be specific to the car. Thanks alot, I do alot of my own maintenance, I'm rather young and I enjoy hearing the feedback from other guys, whether it be about oil changes or rotating my tires.
Ben
Old Nov 30, 2007 | 12:41 PM
2k S4's Avatar
Hey thanks alot man, I appreciate it. Do you think that I can make another 10 hour trip if i continue to maintain an eye on the coolant level where it is, it is approx. an inch above min.(it would be in 25-30 degree weather)? I know that there is coolant already stored within the engine, and I have heard stories of guys who have filled above min. and experienced an overflow when the system starts to circulate. That is why I am apprehensive to fill the coolant level much higher. Any thoughts? Also should I be able to add any sort of red coolant/antifreeze or should it be specific to the car. Thanks alot, I do alot of my own maintenance, I'm rather young and I enjoy hearing the feedback from other guys, whether it be about oil changes or rotating my tires.
Ben
If you watch the level you should be fine. Just put distilled water in there. Then when you get the leak fixed you should flush the system & use the proper Audi Coolant.
Old Dec 2, 2007 | 02:59 PM
know what, my apologies, the coolant level is actually approximately an inch below the mininum line. I would like to fill it up to the min line, and maintain a close eye on it during my trip, however what type of coolant should I put in there before I get driving? I am a little apprehensive about using distilled water, as I am in an area where it has been below freezing for the past few days. Thanks alot, I appreciate all of your help 2k s4.
Old Dec 2, 2007 | 04:27 PM
RED_01's Avatar
As 2ks4 stated, use the proper Audi coolant Go to the dealer and get the correct coolant you wont find it at a parts store. I'd probably check the freeze/boil point of the coolant in the vehicle before you top it off.
katcoota
Mar 8, 2009 11:25 AM
Sherman Banks
Aug 9, 2008 02:07 PM
Teutonic2.7T
Jul 3, 2008 11:50 AM
pete47
Apr 10, 2007 07:44 PM
