Pothole Damaged wheel bearing?
Old May 11, 2008 | 11:32 PM
Artrip's Avatar
Default Pothole Damaged wheel bearing?
I hit a pothole of epic proportion a few weeks ago with my right front and have had a noise ever since. It was bad enough to bend the rim, wreck the tire, blow the shock, and knock the alingment out (and of course, it's not the state's, city's, or county's fault). I got new tires, new rims are on the way, as is a new Bilstein (it only had 5K miles on it!!![:@]) But, the issue that concerns me is that the tire makes an out of round noise, especially when cornering to the left. I have tried putting my spare on (non bent rim) and the noise persists. It does not change it at all. The swaybar is fine, as are the control arms and spindle, as far as I can tell. I have tried measuring the runout on the hub with the spare tire on, and cannot see more then a few thousands ofrunout, so the hub doesnt seem to be bent, but, is it possible that the pothole damaged the wheel bearing as well? The noise is constant with tire speed, and does not vary, it happens at the same point of hub rotation every time. I was thinking that the impact might have indented the races of the bearing and that the side loading of cornering to the left makes the noise more pronounced.
Thoughts?
Old May 12, 2008 | 12:57 AM
acamillo's Avatar
Default RE: Pothole Damaged wheel bearing?
its quite possible, the wheel bearings are only made out of aluminum right? So they'd be pretty easy to bend if the right pressure was applied
Old May 12, 2008 | 08:15 AM
sweeds4's Avatar
sounds like a problem I am having. The CV joint is shot. when turning left there is a clunking noise? Also if you are slowing down, is there a clunking noise too? That would be the axle. It's only like $90 from purems. I was replacing mine but they sent me the wrong one! or you can get a pre-greased axle from raxle.com for 175. Pregreasing the bootis a B!tch! haha
look for the front right axle assembly. the boot joint kit is like $10 cheaper but I would just replace the whole thing.
good luck!
Old May 12, 2008 | 09:20 AM
Artrip's Avatar
the outer CV joint and boot have less than 15K on them. The bearing is almost brand new as well. The impact damaged something, I cant figure out what though yet.
Old May 14, 2008 | 10:53 PM
Artrip's Avatar
for those that were interested, it did FUBAR the bearing. Brinneled the inside bearing hub race pretty nice. Big crater in the face where the ***** run.
Old May 15, 2008 | 11:03 AM
Midwest user1's Avatar
An FYI that the City is liable for damage to your car if you hit a pothole. I know two different people who had gotten reimbursed. It wasn't speedy by any means but they are liable as it is there responsibility to fix pot holes as soon as possible. Especially when they are large enough to do what it did to your vehicle. Did you take any pictures of the pothole and your damaged items? That's the first step.
Old May 15, 2008 | 04:16 PM
readimag's Avatar
yeah i agree with that at least you did not have you wheel blow like this guy in the a3 forums that looked crazy. i will look for the pic to post up here.
here it is
Old May 21, 2008 | 10:57 PM
Artrip's Avatar
yeah, I wish myself luck getting anything out of teh city/state/county. It was just outside of teh city, on a state highway, being serviced by the county. I know next time I hit something that bad, I'm going to come to a dead stop right there and not move until the cops and road commision supervisor come and take my statement and complaint. In total it did about $1200 worth of damage to the car.
audisheri
Dec 23, 2014 05:33 PM
Kyle_vdk
Jan 11, 2014 10:25 PM
01AudiA4
Jan 30, 2008 12:13 AM
