Radiator - How to get to the Drain Plug?
Old Oct 5, 2007 | 08:56 PM
to3o's Avatar
Default Radiator - How to get to the Drain Plug?
Planning to do a coolant flush... do I need to remove the front bumper in order to get to the drain plug on the radiator?
Old Oct 7, 2007 | 08:56 AM
2k S4's Avatar
Default RE: Radiator - How to get to the Drain Plug?
Nope, just the lower belly pan. It might be easier to just pull the lower rad hose.
Old Oct 9, 2007 | 04:21 PM
to3o's Avatar
Thanks 2k S4! Do I have to twist the rad hose? I see that there is a sensor. My question is, do I have to twist that plastic part (after removing the metal pin) before trying to pull the hose? This thing is like glued in there... (just like the pinch bolt on the upper right)
Old Oct 9, 2007 | 05:03 PM
2k S4's Avatar
ORIGINAL: to3o
Pull the pin, then wiggle the hose, it will be stuck on there, but then pop off & drench you with coolant.
Old Oct 9, 2007 | 07:28 PM
lathropcarco's Avatar
Sometimes they get caked on there you can also gently take a very skinny flat head screw driver and stick it in and circle around the hose and then give it a little pull. This always works for me.
Old Oct 9, 2007 | 08:38 PM
to3o's Avatar
Thank you guys! I am planning to do a coolant flush after I fix my transmission and boost problems...
Pbcrazy
Oct 10, 2012 06:35 PM
jaybird
Oct 15, 2010 03:48 PM
xb70valkarye
Apr 11, 2008 09:43 PM
meanse
Oct 29, 2007 05:04 AM
lfab500
Feb 13, 2007 12:25 PM
