Random misfire.. ready to give up...*long*
Old Sep 29, 2006 | 04:10 PM
i3uddha's Avatar
Site Moderator/Ninja
Default Random misfire.. ready to give up...*long*
[sm=boohoo.gif] [:@]
ok.. so in my infinite wisdom of trying to save a buck by going to an independant
mechanic (well known in the v-dub tuning circles) & avoiding the Stealership -
I have now spent a small fortune - enough to finance a small army perhaps
in trying to diagnose & fix the problem.
heres a lil background -
I had random misfires in bank 2 - cyl 4-5-6
nothing noticeable on my end - but never-the-less the CEL was there.
First they replaced the MAF - which didnt fix things,
so he replaced the ignition control module ontop of the airbox -
& I had him switch out the plugs as well..
Well, after the ignition control module & plugs -
the misfires went down drastically....
but Im still throwing a code for P0330 - random misfire
he said it was the coilpacks - & I had to replace all 6 of em.. or at least cyl 6.
BS. He also wanted to charge me $100.00 per pack
when i know the going rate is about $50.00
additionally, if the coilpack was bad I know it would have a rough idle,
or if it failed - i would have a flashing CEL... I have neither...
I'm not taking it back to this shop. Does anyone have any other suggestions as to what
is causing the random misfire? I dont notice any rough idle -
and just to try & make sure it wasnt the coilpack I did change cyl 6 coilpack on my own,
just to rule it out. - nothing... CEL came back - same code.
HELP PLEASE
Old Sep 29, 2006 | 04:36 PM
techbod's Avatar
Default RE: Random misfire.. ready to give up...*long*
simple one here its the knock sensor on the 4-5-6 side ( driver side USA ) check the wiring/connections, a common problem is the come lose nip up to 8lb ft
Old Sep 29, 2006 | 05:31 PM
i3uddha's Avatar
Just tried searching for pics / location of the knock sensor ...
nothing.
any tips on how to find it?
Old Sep 29, 2006 | 05:35 PM
techbod's Avatar
knock sensor is just below your headers ( middle of the engine approx 2" below the head gasket ) just below cylinder 4
Old Sep 29, 2006 | 05:41 PM
i3uddha's Avatar
THANK YOU
I'll try it tonight....
you are a life saver....!
too bad u dont live here in the states Dave, I'd only have you work on my car.
Old Sep 29, 2006 | 05:48 PM
onepoint8tee's Avatar
Could be a bad ground. But I would look more to things that can cause you to run rich and missfire like ECTS, bad spark plug/coil pack, MAF, and 02 sensor(s).
techbod's Avatar
good luck and your welcome
dorkfish
May 6, 2013 09:58 AM
daniwood
Jul 22, 2011 10:37 PM
jmc88
Nov 17, 2010 04:23 PM
achTTung
Nov 28, 2008 02:23 AM
