Really bad Squeeling noise, sounds like murder, Any ideas?
that stuff isnt cheap! im gonna try febi, apparently its the same stuff but 10 bucks cheaper. granted pentosin is only 20 bucks but come on its power steering fluid. i can get a quart for like 5 bucks at a local autoshop...ps i still hate my car
How exactly do you flush your power steering fluid because i def. need to do that as well but have no clue how to flush the system. A friend who drives a sti told me he cant just straight up "flush" his system on his car and I assumed that the b5 s4 is way different than some ricer japanese car. If any of you guys could link me to a write up or if its simple enough to just describe yourself it would be appreciated.
btw if i dont need to flush the whole system and change the filter that would be nice to know as well.... I just noticed sourD said that he just added the fluid and was fine... if this is true ill have to just try that first.
dont overfill tho... what i did was jacked up the front end, took a turkey baster and sucked out the fluid one pump at a time, then i turned the wheel back and forth a bunch of times to get as much of the fluid out as i could then refilled and turned the wheel back and forth to get it flowin through again then turned on the engine and had a buddy top it off as i kept turning the wheel back and forth. then drove around for a couple minutes and double checked the level. it was good for a couple days but came back so im going to use a different fluid next
