Rear deck removal on B5
Old Dec 11, 2007 | 10:19 PM
vernonm5's Avatar
Default Rear deck removal on B5
The link on the ultimate DIY thread with directions on how to pull the rear deck (package tray) doesn't work anymore. I need to replace a blown speaker, does anyone know of another writeup somewhere before I start poping clips and flexing plastic?
Old Dec 11, 2007 | 11:02 PM
TwinSnails's Avatar
Default RE: Rear deck removal on B5
You pull the lower seat cushion off by lifting up at the front and pulling hard. Then you pull up and away on the side bolsters and they will come out. You then pull down the folding seats. Then you remove the plastic guards from the child seat anchors and unscrew the bolts under them. The deck is attached with three or four clips in the front which are hard to pull. Pull up on the deck or pry with your hand or screwdriver ( i cracked mine but its not visible at all if you do since the cloth covers it up). Once you get the clips out it will not come out because it is adhered partially. You have to slide your hand under it to peal it off from the metal part of the deck. Once it is loose it will slide out toward you and you can swing it down. You do not have to remove the seatbelts at all unless you plan to remove the deck out of the car.
Old Dec 12, 2007 | 12:50 AM
TKneedsS4's Avatar
100% perfect^^^^^^ follow everyword and dont remove the seatbelts just a PITA that u dont need. work around em
Old Dec 12, 2007 | 03:46 AM
TwinSnails's Avatar
One last thing. If you are keeping your stock headunit and are using aftermarket speakers and have a non bose car you have to reuse the amp which is attached to the driver's side rear speaker. You have to do this by removing the factory speaker by unscrewing it from the amp and then cutting the wires which attach the speaker to the amp. Then reattach them to the new speaker. Audi is retarded and they use all types of random color wires so you can never tell what is ground. If you dont have speaker polarity tester use your best judgement. Usually brown or solid green is ground but they throw a lot of curveballs in the b5 .[:@]
Old Dec 12, 2007 | 09:48 PM
carhopper's Avatar
My 6" subs weren't actually blown. There is a rigid dust cover attached to the voice coil that had broken loose and was vibrating on the diaphragm causing a terrible noise. Removed the back deck enough to get my hand in there and remove that piece and my stock symphony is working great.
Old Dec 12, 2007 | 09:50 PM
SourDieselS4's Avatar
Im pretty sure my decklid speakers are detached. It sounds like someone's in my trunk playing maracas
Old Dec 12, 2007 | 10:47 PM
TKneedsS4's Avatar
hahaha i disconnected the driver side "sub speaker" in the deck because it was rattling bad, you think with me being all into car audio and doing that for my job i would have something nice in there haha...
That was my old car. sweet system, but too heavy im a speed addict now.
Old Dec 13, 2007 | 08:01 PM
RED_01's Avatar
ORIGINAL: carhopper
When I got my car the system sounded great except for a rattle when bass hit. I searched all over looking for the culpritand found that my dust caps were loose also. I removed them both and now it sounds great. I would suggest checking the condition of these caps firstto anyone with factory sub sound issues.
TomKat
Dec 2, 2012 06:54 PM
Prizmatik
Apr 11, 2009 12:27 AM
consequential
Feb 9, 2009 02:30 AM
rhyab1
Jan 8, 2008 08:35 PM
thintzen
Dec 29, 2006 05:42 PM
