S6, 4.2 Tire Size
Old Apr 26, 2008 | 08:43 AM
katcoota's Avatar
Default S6, 4.2 Tire Size
I've search and searched and am confused.
My S6 has 235/45 ZR17 tyres. According to tirerack and other sites, my car doesn't exist.At least not in the US[:-]. The closest I could find is 2002 S6, but they come with 255/40 tyres.
Which is the correct original size and what would be the benefits/problems of putting the 255/40 on?
Old Apr 26, 2008 | 03:01 PM
CamoA6's Avatar
Default RE: S6, 4.2 Tire Size
255/40ZR18 i think is stock
Old May 2, 2008 | 12:45 PM
heywood's Avatar
My stock size is 255/40-17 (US model) and we only had the S6 in the US in 02 and 03. It should have the stock size listed in either the door jamb or the owner's manual. Maybe those are the winter tire size?
Old May 2, 2008 | 01:17 PM
CamoA6's Avatar
Try checking Gas tank lid as well,
Old May 2, 2008 | 11:17 PM
JETSPEED333's Avatar
SoCal Crew Member
i've got this info at work.... i'll post it up tomorrow for yah if no one else does by then...
Old May 3, 2008 | 04:15 AM
katcoota's Avatar
Checked the gas lid a long time ago. Only gives tire pressures depending on load in the vehicle.
Owner's manual was misplaced by previous owner (it was never under the steering wheel).
My wheels look like Camo's. It is not like the S8 which has slightly rounder wheels. I don't know how to explain it, but the 6 spokes in the S8 are not as pointy as the ones on the S6. Am I making sense, or should I post a pic of my dirty wheels?
Old May 3, 2008 | 09:37 AM
SoCal Crew Member
****... my tire/wheel app book does not have the s6 in it, lol. you need to go witht he same size tire that came off, that sounds right. you can order the tires from tire rack with out applying you vehicle application....
Old May 3, 2008 | 10:04 AM
katcoota's Avatar
I'm guessing one of two things regarding my tires:
1) The previous owner downsized for some reason, or
2) The size I currently have is for the European model of 2001, which is a thinner tire than the US model's tires.
I'll have to find an S6 around here to compare tire sizes with. Now that will be a challenge.
Old May 3, 2008 | 12:32 PM
SoCal Crew Member
found it!
2002 audi S6 Advant specs=
tire: 255/40ZR17 94Y (psi @36)
rim: 8J 5-112mm ...torque to 89
..do you have the factory wheels still???
mystrodo
Sep 2, 2009 09:41 AM
fidelite
Jun 24, 2008 02:06 PM
EliteTuning1
Jul 25, 2007 04:15 PM
jtv4.2
Aug 29, 2006 02:00 PM
angelo_nyc1
Jan 7, 2005 06:33 PM
