so great
Old Feb 27, 2008 | 04:46 PM
DavidgotanAUDI's Avatar
Default so great
Well I have done it, driving down the road today I was just shiftung along, nothing hard just havin a little fun.... Well all of a sudden I couldnt downshift into 2nd or 1st. I knew I was having problems with the syncros. So I called the dealer they want 4,837 to replace the damn things!!! I thought well ill stick it out, now the car wont go into 1st or 2nd at ALL!!!!!
Now my question is, should I just replace the trans or anyone have any other places to go to get the work done that would be a little better on the wallet????
Old Feb 27, 2008 | 11:13 PM
joshf's Avatar
Default RE: so great
get a independent shop that works on audi, and have done s4's the parts for a rs4 clutch and lw flywheel is only 1,300 then probably 800 to 1000 in labor
so thats going to be around 2400$, ands4 oem is cheaper maby 400-500$you may need a flywheel too
for thatamountstlrs trying to charge you and tried to do to meI got all my mods in my sig an my timing belt done
Old Feb 27, 2008 | 11:25 PM
Paulyworld's Avatar
Member
he needs a tranny rebuild.... not a new clutch... but that is a tough decision... i dont know how easy a new trans would be to find but if it was my car i would have it rebuilt to make it stronger
Old Feb 28, 2008 | 01:11 AM
skeezo3000's Avatar
I had my trans completely rebuilt about 300 miles ago. I payed $3750 for it. I too had the first gear second gear problem. I also had the whole clutch assembly replaced along with clutch master and slve cylinder. Not sure if one could have to do with the other but my clutch master was siezed up. Now everything is like butter. About another 12-1500 for clutch and mas/slve cylinder install
Old Feb 28, 2008 | 01:14 PM
joshf's Avatar
maby it didnt set right last time the clutch got installed ? dont know
Old Feb 28, 2008 | 05:34 PM
audi ops's Avatar
there is no real reason why to make it stronger, when you have it done just make sure you get those newer syncros from jhm or vast or whatever it is
Old Feb 28, 2008 | 05:37 PM
SourDieselS4's Avatar
Id use stasis.
Old Feb 29, 2008 | 06:16 PM
Doesnt stasis make trans for these cars, and if they about how much are they??
Old Feb 29, 2008 | 06:17 PM
they do have a website!
http://www.stasisengineering.com/Thu...x?ID=10&VID=51
Old Feb 29, 2008 | 07:20 PM
shawncumberland's Avatar
ORIGINAL: HP Addict
4700 for the close ratio... jeebus... that is half of what I bought the freak'n car for.
