squeaky door? problem solved...
Old Mar 1, 2006 | 05:40 PM
psyct1's Avatar
From: born in Brooklyn, reside in Woodbridge Virginia
Default squeaky door? problem solved...
for about the last month or so, my driver side door squeaked really really bad when I opened it or closed it slowly... i got tired of hearing it, and instead of buying WD-40 I wanted a fix RIGHT THAT SECOND (had a bad day, little things were buggin me) and i remembered i had some Audi DOT4 brake fluid in my trunk from a recent brake line flush... I grabbed one of my hundred rags in the back and slowly dripped the fluid on pretty much every hinge on all doors... not only did the squeaking stop but, the doors open and close much much easier now... just be careful not to get any on anything else but the hinges...
figured i'd spread the wealth a bit...
Old Mar 5, 2006 | 08:15 PM
dankhound's Avatar
Default RE: squeaky door? problem solved...
Considering theres about 100 different lubricants that will work better than brake fluid without the danger of removing the paint, I'd have to ask,why?
Old Mar 5, 2006 | 10:35 PM
cary12's Avatar
My door was squeaking really bad and I used WD40. That was about two months ago and it has been perfect ever since.
Old Mar 6, 2006 | 04:40 PM
Jestnomen's Avatar
6th Gear
Yeahhh brake fluid is corrosive afaik. Use white lithium grease.
Old Mar 7, 2006 | 02:49 AM
psyct1's Avatar
shiiiiiiiiiit....
ORIGINAL: Jestnomen
Old Mar 8, 2006 | 01:09 AM
99a4audi's Avatar
i used WD-40 and it worked great
Old Mar 14, 2006 | 05:44 AM
NavyS4guru's Avatar
good news is wd-40 will get rid of the other.
i usually use engine assembly lube...
edub18t
May 28, 2009 03:53 AM
mypreludeisred
Apr 21, 2008 01:57 PM
morrisonjd84
Oct 25, 2007 08:14 PM
cary12
Dec 27, 2005 08:03 PM
