Is there any way of getting to the ko3s without pulling the motor?
Old Oct 24, 2007 | 10:52 PM
TwinSnails's Avatar
Default Is there any way of getting to the ko3s without pulling the motor?
Just wondering if its possible.
Old Oct 25, 2007 | 02:20 AM
DavidgotanAUDI's Avatar
Default RE: Is there any way of getting to the ko3s without pulling the motor?
a guy posted one here and said he did it and exactly how he did it but i couldnt find the post so you will have to look, but like i said he said he did it so we dont really know. none the less it is still a bitch getting the damn things out
Old Oct 25, 2007 | 07:29 AM
Mott Power's Avatar
Yeah, Devil said he pulled his out through the front of the car, had to take off the bumper, radiator, etc., quite a tight squeeze but apparently it worked. Send him a PM for more details.
I was able to get them out by dropping the subframe and lowering the engine and tranny a bit using a GOOD jack. Still hard to get a couple bolts but works if you can be patient, just gotta make sure not to strip them.
Old Oct 25, 2007 | 09:03 AM
pyrotechnique's Avatar
Yeah, there's a mechanic around where I live (Charleston, SC) that can do it without taking the motor out as well.
Old Oct 25, 2007 | 09:50 AM
ha I knew it I was right some one did say they can do it
Old Oct 25, 2007 | 10:25 AM
TKneedsS4's Avatar
Eh idk , not dropping it is great and all but since your already in there mind as well pull the motor, re do your cam tensioner seal, motor mounts, and all those cheap dumb parts that have a tendancy of going bad.
Old Oct 25, 2007 | 12:46 PM
TwinSnails's Avatar
ORIGINAL: TKneedsS4
I hear that. It just seem like a royal pita to pull it.
Old Oct 25, 2007 | 01:33 PM
Mott Power's Avatar
it's mostly if you just don't have the equipment to drop the motor
Old Oct 25, 2007 | 03:46 PM
one thing I would pull the motor and when you have it out do all the little stuff and if you have the money replace the clutch and depending on what it looks like get the flywheel turned most machine shops do it for like 30 or 40 bucks. I would make it a lot better, and 10000 miles down the road you dont have to pull it all out again you know?
Old Oct 25, 2007 | 08:56 PM
Superdug's Avatar
SoCal Crew Member/White Devil
what if you just pulled the tranny i have heard it makes it easier to get to the dp's can you also access the turbos
