these brakes are such a pain!
Old Apr 18, 2008 | 01:13 AM
washyourrhands's Avatar
Default these brakes are such a pain!
so i got in my new brakes yesterday and i was putting them on today and everything was going smoothly till i got to the point where i had to take the caliper off. I couldnt not find the right size to unscrew the bolt that has the plastic cover and i read a tutorial that said it was a 7 and it was too small and an 8 was too big
then there were these other bolt i believe they were carriers bolts that were 22mm
not possible to break the sealand get them off
next week ill have access to a lift so when i put my exhaust on ill do all that too i guess
just frustrating
i ended up just changing my pads
if theres a really good tutorial someone knows of thatd be great
Old Apr 18, 2008 | 03:09 AM
Audi_Skydiver's Avatar
Default RE: these brakes are such a pain!
I would like to know about this as well. I need to replace my front rotors as one is slightly warped which sucks a lot.
Josh
Old Apr 18, 2008 | 08:27 AM
SourDieselS4's Avatar
Ya i had a bitch time removing my calipers, had to use a breaker bar. Just keep at it i guess
Old Apr 18, 2008 | 10:37 AM
CamoA6's Avatar
The ones with the rubber caps on them are a 7mm allen I am almost certain as I do about 2 a day. But they should also be for the carrier. Not the caliper itself. The caliper its self is just a 17-19mm head if I am not mistaken...
I'm also pretty sure I can get the pads and rotors out without removing the caliper at all.
I just pull back the retaining clip and push back the pistons with a screwdriver (there are small notches for one) And then I just pull the pads out the back.
If the caliper actually has to come off crank it with a 17-19 mm head with a breaker bar. they can be real tight. then use a small bungie cord and suspend it from a control arm to keep it out of your way.
Old Apr 18, 2008 | 11:43 AM
audi ops's Avatar
One word BRAKLEEN!!! It does everything we can't. Heck I wash my dishes with it...
Old Apr 18, 2008 | 11:59 AM
techbod's Avatar
the tool required is a star drive or torx bit so caution because if you strip the bolt head it will need drilling out and if you dont know how it will cost you a new carrier, to drill out use a small drill it so it dosnt catch the threads of the caliper then use a reverse threader tool to remove the weakend surplus of the bolt
Old Apr 18, 2008 | 01:19 PM
i really hope the guy who owned it before didnt strip that bolt because the 7 allen head is too small
i tried getting the rotor off without taking off thecaliper but it was just too little room
if i had another cenimeter i could get it off
im gonna try again in a few days
have a fresh mind on it
Old Apr 18, 2008 | 01:30 PM
GL with it!
Josh
Old Apr 18, 2008 | 01:34 PM
yeah thanks man
the ECS rotors are really nice looking too
i was pissed when i couldnt get them on
the ceramic pads defaintly feel nice tho
does anyone have trouble with their brake fluid container cap?
i feel like its leaking out the top of it
any thoughts?
Old Apr 18, 2008 | 07:43 PM
Reiem125's Avatar
To take the rotors off it's pretty simple. For the front there are two big bolts that hold the caliper on I believe they are 3/4, I usually loosen the bottom one almost all the way but so it's still on then I take the top one all the way off and pivot it down then the rotor should just be able to be lifted out. I do it that way so I don’t have to support the caliper with wire or anything. There also is a bracket that secures the brake lines to the caliper that you might have to take off to get to that top bolt. Install is the reverse. This is how I do my brakes, I'm pretty much a expert on these brakes now I've taken them apart and back together about 15-20 time since I've owned the car(long story)
