Timing Help
Old Nov 23, 2008 | 07:38 PM
Nice02S4's Avatar
Default Timing Help
Car is running and sounding fine. I needed to change cam seals and TB. I have gears off, seals changed and everything is marked. Crank gear is lined up with TDC. Drivers side cams are lined up and lines and arrows are lined up. Passenger side is a problem. The timing marks on the cams by the chain are not lined up. Because the car is running fine do i leave as it is or should i try moving only the passenger side and line the marks up???
Old Nov 24, 2008 | 09:11 PM
pepsicolla's Avatar
Your timing marks should be dead on. If they are not i would suggest correcting the timing. There is not much room for mistake here. Im surprised your not experiencing interferience.
Audiguruforyou
Sep 20, 2011 01:31 AM
vtraudt
Apr 1, 2011 09:40 AM
B72.0tsline
B7 Models
Mar 3, 2009 01:18 PM
Jessie2k
Aug 5, 2008 01:39 PM
xX|05:A4|Xx
May 3, 2008 08:28 AM
