Turbo kit
to answer your earlier question and you said you want a KIT, get the awe package without the mani's its been developed together, works together and has been a solid deal to work with for a long time plus all the research and development they put into it.
dp's and inlets--1000
intercoolers-----500
tuning/fueling---2100
mounts all around-350
stage 4 clutch---425
RS4 p plate------325
710n valves------90
silicone ebay hose kit--100
misc.-------------1000
close to 9000 give or take 500... i should have close to 400 whp @ 24 psi and when i dump another 1000 for meth and a bigger fuel pump hopefully ill dyno at 460 to 475 whp... and i did all the labor myself...
thats crank.. and it is legit.. but on here we talk in whp.. wheel horsepower.. dont get me wrong, AWE's kit will be fast.. but they are closer to 360 whp or so.. with RS6 turbos, a good tune, methanol and other stuff one could get close to 500 whp.. with a good VAST, EPL or JHM tune on even K04's one can get close to 450 whp..
so in other words when companies claim hp the're not measuring whp,so a stock s4 is 250hp not whp.if thats the case I don't know if I want to spend that much money on the awe tuning kit only to get 360whp.
about you wanting HP and reliability your eventually going to have to sacrifice one for the other. The K04 are much more reliable then the K03. The RS6 turbos will cost you about $1200 more then the K04 and your also looking at needing your btm end built especially if your wanting a RS6 DD.
