Vacuum help please
I was under the hood today and found a vacuum leak. It was coming from a valve with 4 nipples on it, connected to the curved hard line which I assume runs to the vacuum resevoir, see pic below.
This is the valve that is broken but i was was wondering if I need to buy this at the dealer or can I go to Napa and buy a similar valve?
So I can just go get a T and another fitting and hook it up, right? As long as all the hoses are hooked up it should be fine. What about the hard plastic line that connects to it? I had to snip little off so I could get the valve off and now I can't fit the valve back in.
The same part broke in my hands one week ago as I was replacing my auxiliary pump. Some heat goes through these plastics and they get weaker with the miles. I got the part from the dealer for $35. ECS has it. It's called Vacuum Check Valve for $23.18.
http://www.ecstuning.com/stage/image...1/600/2481.jpg
redmond1501
May 12, 2014 02:55 PM
