VAG COM codes
Old Jun 9, 2007 | 12:23 AM
1S1CKS4.5's Avatar
Default VAG COM codes
ok finally got my vagcom workin right (needed an update) and i got 7 codes and im not likin the look of em please help me out i want to get this **** fixed sooni kno theres 2 EGT sensors but idk which one to replace and they got for 288 each at ECS which the mother ****** aint cheap! and i accidently added 87 to the s4 and i finally waised it havent refilled it with 93 yetsincei havent driven the car in a week what is a bank1 sensor? please help me i was thiknin of gettin a tune up such as distributer, plugs and wires hopin that will fix the issue with the missfires
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
17870 - Exhaust gas temperature control bank 2 Range/Performance
17521 - Bank1-Sensor1 Internal Resistance too High
16684 - Random/Multiple Cylinder Misfire Detected
16685 - Cyl.1 Misfire Detected
16688 - Cyl.4 Misfire Detected
16686 - Cylinder 2 Misfire Detected
thanks guys
Old Jun 9, 2007 | 03:36 AM
Baskin 4.2l's Avatar
Default RE: VAG COM codes
Wow ok you need some serious help.
OK first your car dose no have a distributor or plug wires for that matter. The only wires you have going to the plug go into the coil pack and they should never be replaced
also bank one is on the passenger side
your misfires are going to come from the Bad o2 sensor in most cases. Add a bad EGT and you are definitely going to have some issues
Lastly it helps when you proof read what you post. If you want people to read and help it only makes it easier for people to help when there is not words substituted for packs of letters in text message form. I know that I am no literary genius but it always helps when things are spelled right and the reader doesn't have to spend time trying to figure out what you are trying to say
Thiswas meant to be helpful not harsh
Old Jun 9, 2007 | 03:55 AM
JETSPEED333's Avatar
SoCal Crew Member
^ no....
very well put... we are here to help....and the more understanding it is the better we can help
Baskin is defintly on the right track. Looks like an O2 sensor is out
Old Jun 9, 2007 | 11:29 AM
1S1CKS4.5's Avatar
ORIGINAL: Baskin 4.2l
no no ur not bein harsh at all sorry it was late and i had just came from a wedding at that pint, anyways thanks alot so i should replace the O2 sensor and the passenger side EGT sensor?
Old Jun 9, 2007 | 02:33 PM
1S1CKS4.5's Avatar
point*
Old Jun 11, 2007 | 03:33 AM
You really need to replace both as they work together to adjust the fuel. The EGT is the most important but the car will misfire and run rough unless you change the 02 sensor
I know that the EGT sensor is expensive.... but Vast has 02's for 100 each that is 1/2 what the dealer charges. Check them out they usually beat most people's prices so ask them about the EGT as well
But all in all you really need to replace both
Old Jun 11, 2007 | 11:40 PM
1S1CKS4.5's Avatar
thanks alot of the info man i appreciate it now all i need to do is raise the money to get the sensors lol
Old Jun 12, 2007 | 09:53 AM
CamoA6's Avatar
EGT sensors are not fun. neither is an 02. both will kill performance. Just get them ASAP.
Did the car blow black smoke at all?
Old Jun 12, 2007 | 12:07 PM
1S1CKS4.5's Avatar
no never did, i havent driven the car ever since the post its been sittin in my garage but as far as i kno its never spit out black smoke
Old Jun 12, 2007 | 12:41 PM
Coop's Avatar
Shoot for the 02 first, but both sensors are not difficult to replace, but be careful not to pull threads out, and take care not to damage the head of the EGT when replacing it.
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
