Very bad misfire bad mpg
Old May 19, 2010 | 12:51 AM
striker3000s's Avatar
Default Very bad misfire bad mpg
The Car is an 02 S4 B5
Vag-Com gives me random misfire, misfire cyl 5, and misfire cyl 2. I replaced the coil pack and plug in cyl 5 and the car worked great for around 20 min. then back to rough idel and even rougher driving. If I get on it at all the CEL starts blinking. The car also gets very bad MPG now. And advice would be helpfull.
Old May 19, 2010 | 02:58 PM
ilackav8's Avatar
you should replace all of the CPs at the same time. I had a similar issue when mine went. One went bad,replaced it and everything was fine for a few days.then the other 3 went all at once. i bet thats your problem
Old May 20, 2010 | 01:17 AM
mys4.org's Avatar
What gap did you put your spark plugs at? There is a lot of wrong info out there about spark plug gap. The OEM specs are .016 - .024 inches.
Old May 29, 2010 | 08:02 PM
Deb38's Avatar
Are your plugs getting fouled up? Check 'em to see if they are getting soaked in gas.
Old Jun 4, 2010 | 05:34 PM
bottlecap's Avatar
coil packs orrr the part that controls the coil packs. i cant remember the name
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
