a weired problem
Old Jan 2, 2007 | 04:35 PM
m3th0d's Avatar
Default a weired problem
Ok first of all hola to everyone
Second I have already searched and couldn't find any posts with anyone having the same problem.
What is going on is I have somewhat of a clicking noise coming from the front driverside wheel and also a very metallic rattling when I go over the slightest bump, BUT no rattling if I have the brakes pressed. I checked and best I could tell without taking the wheel off that the caliper is bolted up fine. Any ideals?
Old Jan 2, 2007 | 05:10 PM
2k S4's Avatar
Default RE: a weired problem
My first guess would be TRE, or control arms bushings going out.
My next culprit would be a wheel bearing.
Try to push & pull the tire, if it moves & makes a noise chances are its the bearing.
Hack up & remove the tire. Use water pump pliers to move all the suspension arms, and see if any of them pop, or move.
If they do, there bad.
Old Jan 3, 2007 | 03:27 PM
Coop's Avatar
check the fittment of the brake pads/clips in the caliper
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
