What is this connector for?
This is behind the splash-guard on the driver's side front wheel well.
I was pulling it off to remove the ABS controller so I can try to fix my intermittent alarm.
I noticed this connector just sitting there, swinging... not connected to anything.
Anyone know what it's too? I can't see anything that's unplugged.
The only thing right now that doesn't work is my headlight squirters. Maybe it's to them?
[IMG]local://upfiles/36132/69D99339E8064CD1B4CEF00DB8A02363.jpg[/IMG]
Thats a connector that goes to the main engine wiring harness so its gotta be something like a sensor or an emissions system. If you have an automatic it could go to the vaccum pump directly above where the connector is hanging. That or it goes to the transmission somewhere.
ORIGINAL: auditech79
Where is the vacuum pump you're talking about?
The vaccum pump is only equipped on automatic models, its next to the coolant resivior on the driver's side. (bigsilver cap)
Its only equipped for automatic models to aid the assistance for the cruise control, so the cruise control might not always work.
You can see it if you take off the plastic cover by the power steering resivior, it might not have a silver cap though, you should see three wires running into it on the top.
I don't have anything next to my power steering reservoir under the plastic cover.
The connector goes on the bottom of the pump so you WOULD have enough wire but since nothings there and i assume you have no faults, the hell with it let it fu cking chill there!
i got that same wire just hanging around too...i checked on the passenger side...and i see a plug that look the same connecting to the horn....maybe we suppose to have 2 horns?
These are my current failure codes:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-10 - - - Intermittent
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-10 - - - Intermittent
