What PSI are you running your winter tires at?
hmm, you mean written on the actual rubber? i have not noticed, you'd think tirerack would tell you on their page for the tire model itself, but i didn't see it there either.
Silver, yeah I know that the car itself says 44psi, but I'm asking if it changes for winter tires, since the car is delivered with stock tires. Doesn't that have some effect?
I run mine at the same PSI as the stock Contis. I think it's about 40psi in the front and 36 in the back - or roughly midway in the recommended PSI range for the car (check door frame) You should check that your tires can handle the pressure: it should give you the max PSI on the side of the tire.
