What PSI are you running your winter tires at?
Old Dec 23, 2005 | 08:41 AM
toysnob's Avatar
Default What PSI are you running your winter tires at?
Just got Blizzak LM25's on my 18" stock 2005.5 rims. What PSI are people running their winter 18" are?
Old Dec 23, 2005 | 10:36 AM
scarzie's Avatar
Default RE: What PSI are you running your winter tires at?
doesnt it tellu on the side of thetire what psi to run them at???
Old Dec 23, 2005 | 03:11 PM
toysnob's Avatar
hmm, you mean written on the actual rubber? i have not noticed, you'd think tirerack would tell you on their page for the tire model itself, but i didn't see it there either.
Old Dec 23, 2005 | 04:31 PM
scarzie's Avatar
ya i think on the rubber, but im not positive on that one
Old Dec 23, 2005 | 05:48 PM
SILVER_B5S4's Avatar
It should say on either the inside of your gas tank cover...or on the door jam on the driver-side door!
Old Dec 23, 2005 | 08:31 PM
toysnob's Avatar
Silver, yeah I know that the car itself says 44psi, but I'm asking if it changes for winter tires, since the car is delivered with stock tires. Doesn't that have some effect?
Old Dec 29, 2005 | 02:44 AM
S4sweeteeteeRS's Avatar
yes, check the tire itself, it will tell you the maximum psi.
Old Dec 30, 2005 | 07:38 AM
peter919's Avatar
just run about 30 or so... i got the same tire as you... it works for me...
Old Jan 5, 2006 | 05:29 PM
claudio's Avatar
I run mine at the same PSI as the stock Contis. I think it's about 40psi in the front and 36 in the back - or roughly midway in the recommended PSI range for the car (check door frame) You should check that your tires can handle the pressure: it should give you the max PSI on the side of the tire.
Old Jan 11, 2006 | 11:30 AM
toysnob's Avatar
For those interestd, the Tire itself says no higher than 40psi, so I keep them at 38psi. I am eager to get my summer tires back on.
