Wierd cluncking/popping noise?!
Old Sep 20, 2006 | 08:04 PM
boastud's Avatar
Default Wierd cluncking/popping noise?!
On my 2001.5 Avant, the rear drivers side wheel im getting a wierd popping/clunking noise. It started when i would turn, but now its pretty constant. At first i thought it was just the wheel bearing, but thought i would try to get some other opinions. Any input would be appreciated.
Old Sep 20, 2006 | 10:03 PM
FourDs's Avatar
Default RE: Wierd cluncking/popping noise?!
Wheel bearing--my vote.
Old Sep 26, 2006 | 03:26 AM
tjbrunz's Avatar
Also check the bottom of the rear strut/shock. There is a nylon (rubber) bushing that can wear out. it should be easy to see from the rear. When the bushing wears, it allows some slack in the suspension, this can also cause abnormal tire wear as well. When you look at the hole for the bushing it will be round and tight, a worn one will be oblong, and the whole shock will need to be replaced.
Old Sep 26, 2006 | 03:52 PM
Mott Power's Avatar
wheel bearing
Old Sep 29, 2006 | 04:29 PM
boastud's Avatar
Wheel Bearing it was. Thanks For the Help!
Old Jul 7, 2007 | 05:55 PM
duburban's Avatar
Bringing this one back. Same thing is happening to me, but, I noticed it after a new bearing was put in. Could it have been put in wrong?
Old Jul 7, 2007 | 08:44 PM
TKneedsS4's Avatar
very piossibley put in wrong one of my front ones was once. But go iwth the rubber bushing at the bottom of the strut/shock assembly.
I have a clanking spoons noise ocming form mine that i cannon find.
pbrules10
Feb 15, 2011 11:13 PM
olympique51
Jun 14, 2010 11:09 PM
egyptianluver88
Nov 29, 2007 12:56 AM
mlo517
Jul 29, 2005 02:37 AM
jstaco
Jun 26, 2005 11:06 AM
