Will i Pass?
Old Dec 27, 2007 | 08:45 PM
ARIaudiS4's Avatar
Default Will i Pass?
well guys i failed my first EPA testing about a month ago, i fixed all my codes i had like a vacuum leak p1136. ..... and everything works fine now.. no check engine everythings great. but when i did VAG-COM readiness tested i got "failed or incomplete" for catalytic converter... what could be causing this? can i hide it somehow with vag com? and will i pass emissions?
Old Dec 27, 2007 | 08:59 PM
Mott Power's Avatar
Default RE: Will i Pass?
pfffff, emissions
maybe a leak or bad o2 sensor... or maybe bad cat, just to name some of the obvious
it doesn't say anything else in the code?
Old Dec 27, 2007 | 09:28 PM
ARIaudiS4's Avatar
I dont have any faulty codes... i got rid of my leak. and i changed 3 o2 sensors already.... just in the READINESS area everything passes and then for catalytic converters it says failed or incomplete
Old Dec 28, 2007 | 12:42 PM
2k S4's Avatar
Once you reset the codes, you reset the readiness codes. The only way to get them to the "OK" is to drive the car for a while & not throw any emissions related codes.
It can be 50mi, or 150mi till they reset to OK.
hiwords
Aug 19, 2009 12:20 PM
slideitsidewayz
Nov 23, 2008 05:32 PM
slideitsidewayz
Nov 23, 2008 05:31 PM
