1999 B5 S4 Coil Pack issue
Old Nov 30, 2014 | 01:56 PM
Aviatorlgb's Avatar
Default 1999 B5 S4 Coil Pack issue
Hi Guys,
This must be a question that has been asked before but I can't find anything. Maybe someone can help?
I have a coil pack issue I think. I've had the same issue before and solved it with a new coil pack.
The question is this - Is it possible to test the coil packs to find the bad one without buying a new one and swapping it out one by one with a test drive until the problem is solved?
Thanks!
Old Nov 30, 2014 | 02:50 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Thread moved to the S4 forum.
If you think you have a bad coil pack, simply start the car and unplug the coil packs one by one. If the idle gets worse that coil pack was working properly, if you unplug it and there is no change you know that cylinder was not firing properly. Whether the fault is actually due to the coil pack or something else takes more testing.
Old Dec 1, 2014 | 05:07 PM
Aviatorlgb's Avatar
Hi, thanks for your reply.
I swapped one out today and chose it because it was the only one I hidden swapped before. By luck it seems to have helped. Unfortunately the problem was intermittent and only under acceleration and I still get some sort of misfiring at times even after the swap.
It's one of those annoying problems that only I seem to notice because I know the car so well. Grrrr...
gabiosz
Nov 15, 2011 05:13 AM
7808
Nov 20, 2010 03:40 PM
kraylon
Jul 29, 2009 12:19 AM
AudiATX
Sep 9, 2008 10:12 AM
sdboarder84
Sep 30, 2007 01:41 PM
