2.7T - exhaust cut out valve
For me (daily driver, currently stage 2, all on deck for RS6 build), it would give me the option between quiet and sporty. Open downpipes are an absolute no-no for me. All soundtracks at the 'allroad exhaust thread' have the juvenile 'coffee can sound' (some just replace the mufflers with straight pipes) and/or unacceptable droning.
If the Miltek on the 2.7T (with resonator, naturally) produces the same tone as it did on my 1.8T AEB, then that will be the 'end solution'; but will be out of reach financially for quite a while.
Solutions I can envision:
a) custom X pipe with longer 4" middle section, one 4" cutout
b) stock or normal X pipe, 2 cutouts for stock diameter (2.25"?), parallel operation.
With b) a straight forward 'cut in' install (but 2x hardware) and a) a more complex custom fab and install, but only 1x (larger) hardware.
In any case: manual push-button operation, plus home brewed relay controlled either by boost, RPM or throttle position signal
someone on audizine has the dual cut-outs, from dmh, paired to ssautochrome 3in dp's and it sounds amazing.
Even just gutted dp's to dual cut-out sounds good. i think this would be the best solution considering youre gonna have to get new dp's when you do your turbo upgrade.
which ever way you go that home brew relay sounds like an excellent idea.
