B5 LED display change
Old Jul 3, 2018 | 06:23 PM
ZeBaarda's Avatar
Default B5 LED display change
Hi everyone,
I have a bad led display (common problem for these models)
The question is very simple and probably very stupid
READY?
Should i search for 3gen donor panel from gasoline models like mine (i have a4 b5 year 2001 2.4 AML) or the LED display will fit from diesel cars too, giving the fact, that they are the same FL models from year 2000/2001? I dont need the whole instrument cluster, only the LED display..
Old Jul 4, 2018 | 02:07 PM
A4TurboGuy's Avatar
IF it works, your mileage will change, as it is stored in the cluster.
Old Jul 4, 2018 | 03:22 PM
ZeBaarda's Avatar
lcd
Thats right, its stored in the cluster, but not in the LCD
I wont change the cluster, i just need the cluster for the LCD, i will resolder the working LCD into my cluster..
The question is, should i search for a cluster from only b5 year 2001 and my engine code AML or can i search any cluster from B5 Facelift gasoline cars from 2000 and 2001?
Old Jul 5, 2018 | 12:03 PM
A4TurboGuy's Avatar
You better be REALLY good at soldering. I can solder pretty damn well and I still sent mine out for R&R.
If you do it yourself, I would imagine your best bet would be to find one with your same VIN code (IE 8D)
G/L
Old Jul 5, 2018 | 01:16 PM
ZeBaarda's Avatar
Soldering isnt a problem, im pretty sure i can do it, i have experience, but will see, if its very tricky i know a guy who is a pro in electronics..
trev123
Sep 25, 2012 03:00 PM
Mr. Phil
Feb 17, 2011 08:32 PM
david9999
Jan 27, 2008 11:51 PM
ebf
Dec 9, 2005 03:26 PM
awol
Nov 30, 2004 12:58 AM
