Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
2000 A6 quattro Avant. Rear wheel bearing
Old Nov 6, 2014 | 07:14 PM
jdmmikeyd's Avatar
Default 2000 A6 quattro Avant. Rear wheel bearing
I have a 2000 A6 Quattro Avant. The passenger rear wheel is locked up. I was told it is the wheel bearing. Can anyone tell me how hard it is to change out? And is it possible that the bearing is the cause of my problem??? Any help would be greatly appreciated
Old May 21, 2015 | 09:08 PM
ImTheDevil's Avatar
It could be a bearing - if so you'll need a press to change it. Try dismounting the caliper from the hub. If you can, then a bearing is likely. If you can't get the caliper off, the caliper is seized or the e-brake mechanism is stuck and you'll need a caliper (happened to both rears on my A4).
ECS Tuning
Oct 16, 2014 03:31 PM
b5quattro
Sep 15, 2011 02:02 PM
frettfreak
Apr 6, 2010 02:36 AM
kurtkarl
Oct 2, 2008 10:59 AM
lacrosse22
Mar 5, 2007 02:15 AM
