Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
ABS system
Old Jun 17, 2021 | 01:58 PM
ttilley's Avatar
Default ABS system
Just purchased 2002 Audi TT Quattro; has ABS light on. Seller mentioned rear brakes need attention so started there. Found broken coil springs both sides so I am replacing them with the sear on top and the rear shocks. However, still looking for ABS problem. Cant really locate rear ABS sensors. Could they have removed them?
Second quesyion. Checking the fronts and have located the ABS sensors and look okay. However, on the drivers side the line to the AB S senor has a splitter and another line going to the bottom side of the caliber and the connection looks bad; wired bent at the connector. I have to either get under it or remove the caliber. What is this second line only on the drivers side?
I will probably replace all sensors however, why can't I find them in the rear, I know what the part looks like, but the rears may just be rectangular box shaped connectors in the line going to the caliber.
Old Jan 19, 2024 | 08:03 AM
davideidson's Avatar
The ABS light on your 2002 Audi TT Quattro may be due to damaged rear ABS sensors or their removal. Rear ABS sensors are typically rectangular box-shaped connectors in the brake line leading to the caliper. If they're missing, it could explain the issue. Regarding the driver's side, the additional line from the ABS sensor to the caliper likely serves the brake pad wear indicator. Inspect the damaged connection closely; replacing the sensors and addressing the damaged wiring may resolve the ABS light. Consider consulting a mechanic or Audi specialist for a comprehensive diagnosis and effective repair.
Nvrgvup
Aug 27, 2011 08:02 PM
tangerine
Jun 23, 2010 03:29 PM
rhys
Mar 22, 2006 01:23 AM
Diavan
Dec 20, 2005 02:51 AM
aRIf
Jun 4, 2005 12:19 AM
