Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Front Suspension Sensor Issue.?.?
Old Jun 25, 2011 | 10:07 PM
SuperSage's Avatar
Default Front Suspension Sensor Issue.?.?
I'm having a problem with my front suspension not raising up, there seems to be air pressure in both front bags, although the passenger side is lower than the driver side. When i start my allroad the compressor comes on and the level one suspension light flashes, but i never get any height out of the front suspension. The rear seems to be fine and stays at a normal... I would say level 1 or 2 height. Then the pump stops and the air suspension dash light stays on. Oh and by the way, every time I start the car the air suspension dash light flashes until the pump stops and then the dash light stays on. Im thinking it may be the air valve control box may have a sticky valve, so i did add a few drops of air tool oil. No luck. So now im thinking that it could be a sensor issue OR a trouble code issue. Am i on the right track here??? If anyone has any suggestions please let me know. Also if there are any friendly people with a code scanner in my area that may want to help me out that would be Great! Im just outside of Indianapolis.
Thanks Dave
avdwaal1
Feb 25, 2014 09:33 AM
mcbk1452
Jul 13, 2012 09:11 AM
perryt
Sep 8, 2010 08:54 PM
jayj93pgt
Jul 22, 2009 11:12 PM
