Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Power Steering
Old May 16, 2010 | 01:10 AM
Davey89's Avatar
Default Power Steering
Hey,
I don't know if this is the proper place to post this, but I will go ahead. I've noticed that my steering is really loose, well - not firm at all. It wasn't always like this, and frankly the car is almost too easy to turn. Is this just me? Or is there something wrong with the power steering maybe?
Thanks in advance
Old Jun 22, 2010 | 01:08 AM
sandy's Avatar
There may even be a chance of an improper alignment of the front suspension. If this is the reason, then re-align the suspension as per the recommended specifications. Ensure that there is no major leakage in the pump or gear by inspecting the pump pressure. Replace damaged pump parts or the whole pump if needed. Check if the pump belt is loose, if it is, tighten it. The steering may also be hard to turn if the is amount of lubricant in the suspension or the ball joints is insufficient. You would need to lubricate, or even replace parts if necessary.
a3turrell
Jan 14, 2012 05:23 AM
Lastb0isct
Feb 17, 2009 03:15 PM
Kobe Diesel
Feb 20, 2008 10:38 PM
