Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
RS4 Subframe Question
Old Aug 4, 2016 | 11:10 PM
AttingerNY's Avatar
Default RS4 Subframe Question
Hi - first post from a new member. Have a 2008 RS4 coupe.
Need to replace my subframe. I got a used subframe from a 2008 S4 - didn't realize it was a convertible. Structurally they are identical except for: (a) 2 small attached fixtures for the additional attachments for the cabriolet rigidity (no issue), and (b) the bolt bushings.
In my original subframe, the bushings consist of a metal core within a rubber surround bushing. In the Cabriolet subframe, the whole bushing is solid metal. Both bushings appear to the same dimensions. Other than perhaps a little more road vibration from the lack of a rubber surround, are there any reasons why I cannot use this subframe?
Attached Thumbnails RS4 Subframe Question-rubber.jpg   RS4 Subframe Question-metal.jpg
saabu
Oct 8, 2014 01:23 PM
TeeterTawter
Nov 24, 2008 01:18 AM
o0Quicksilver0o
Jun 5, 2007 11:54 PM
joblessone
Apr 27, 2007 08:46 PM
auditt225
Apr 5, 2007 11:21 PM
