Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Spring chop
Old Nov 19, 2008 | 06:57 PM
tdi-rs4's Avatar
Default Spring chop
have a a4 2002 tdi droped it onto eibach lowerin springs added 19s but its not as low as id like.. does anyone know if i cut off another coil will there be a problem??
Old Dec 18, 2008 | 01:07 AM
MissionCtrl's Avatar
DO NOT CUT YOUR SPRINGS!!!! ever, seriously. I know its a cheap/free and easy fix, but it ruins your springs/ride. Sell your springs and get coil-overs, or buy the ecs spring to coilover "conversion" kit.
Old Dec 21, 2008 | 11:39 PM
Prizmatik's Avatar
Have you had a bad experience?
Old Dec 28, 2008 | 12:42 AM
ImTheDevil's Avatar
They're progressive springs. Start cutting coils off and you're going to F up the dynamics designed into the suspension. You won't have the proper damping control (which can lead to shitty ride quality, worn struts, and possible loss of control in some situations), and will likely visit your bumpstops frequently. Seriously, leave the coil-cutting to the 1988 four-door Civic "Type-R"s that seem to infest every town. If you want to be low, do it correctly.
jasondmaguire
Jun 14, 2009 04:10 PM
myslow1
Feb 23, 2009 10:22 PM
rawburt
Aug 6, 2008 06:40 PM
SHAYs4
Mar 1, 2006 12:51 AM
AlmondA4
Feb 17, 2006 02:29 AM
