Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
What comes with Coilovers
Old 07-11-2007, 12:09 PM
SouRce4's Avatar
Default What comes with Coilovers
So i bought Koni Coilovers used and they are in great condition. I am wondering what parts should come with the set and what tools i will need to install them. The reason i ask is because there are no tops to the set so i will have to compress the springs to put them on the shock. Do i use the stock hats or tops or w/e they call them?
[IMG]local://upfiles/21786/2E0D6F9256614863932EC702A5A7F35A.jpg[/IMG]
[IMG]local://upfiles/21786/A32EDD7FFCBE4754BDC0BA66BFB1293C.jpg[/IMG]
Old 07-11-2007, 04:50 PM
97A41.8t's Avatar
Default RE: What comes with Coilovers
You will use the stock top plate, bumpstop, and rubber thing that goes above the plate. You will need the tool to adjust the coilover height.
You can use a spring compressor to install the springs onto the shocks, or you can lower the adjusters all the way down, pull the shock completely out, then put the nut on. I can't really see but you should have locknuts that come with that set.
Old 07-11-2007, 06:27 PM
SouRce4's Avatar
yea they are all attached to the threaded rods. the tool to adjust i also have. How good is it to use the stock top rubber peice and boot? Will they give me a problem a week down the line?
ericgl
07-24-2010 02:49 PM
jordnalos
06-18-2010 03:23 PM
LM in OH
06-08-2007 07:44 PM
crez
09-04-2006 02:27 PM
m5racer
07-12-2006 02:14 PM
Quick Reply: What comes with Coilovers
