Yet more squeaks....
Ok, I know this is an old topic but please bear with.
Audi TTS mk2 11 plate, the car has a very annoying squeak from the front nearside. It squeaks over a miniscule bump, it doesn't stop during braking, it doesn't squeak in reverse over the same bump. It's not speed related so probz not a bearing but it ONLY squeaks whilst moving, you can't make it squeak by bouncing the car whilst stationary.
Any solutions deeply appreciated!
I think low brake fluid also causes annoying squeak. It is one of the low brake fluid symptoms. low brake fluid noise is an indication that parts like brake pads are damaged. The repetitive applying of force causes damaged parts. please read
https://curateview.com/low-brake-fluid-signs/
