VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Code for Airbag Module
Old Jun 27, 2014 | 10:34 AM
feirstein's Avatar
Default Code for Airbag Module
Just changed out my airbag module.
The old and new used unit have the same part number.
The new unit install turned off the dash light.
But the WSC number is one number off. Is it necessary to recode the new unit for all the airbags to work properly?
Old Jun 27, 2014 | 12:07 PM
Carista's Avatar
Former Sponsor
The workshop code doesn't matter - it's only for "bookkeeping" purposes, so that the dealership knows who was last messing with that module.
But the thing that does matter is the "coding" and "adaptations". Make sure they're the same between the old and new modules. What car are we talking about?
Also, are you getting any error codes from any module, and is your airbag light on?
Old Jun 27, 2014 | 03:25 PM
feirstein's Avatar
My airbag light was on. It is a 2000 A6 Quattro 2.7t.
Which line is the coding and which is the adaptations?
Old Jun 27, 2014 | 03:26 PM
feirstein's Avatar
Old May 26, 2015 | 03:03 PM
sirpainter's Avatar
Default Airbag Module
I have a 2001 TT Roadster. After looking at all the posting here and bring my car to the dealership this is what I discovered.
Airbag light came on after 6 month storage when first starting the car. The car was garage kept not going below 40F with a high quality battery tender connected.
The car is babied never any damage.
I was told the airbag module would need replacement at a cost of approximately 1K USD ouch.
I removed the module in the center console (fifteen minute job)
Sent the module out to Texas for rebooting (great job)
reinstalled and problem fixed. No light.
Total cost: 89 usd for the mean dealership.
64 usd repair and shipping
No light: priceless
Thank you Audi Forum.
Old Jun 17, 2015 | 01:23 PM
barbsaudi's Avatar
I had the same problem with same fix by Texas. Worked OK until first really cold day this past winter when Airbag light came on again.
Old Jun 17, 2015 | 03:59 PM
sirpainter's Avatar
Did you call the shop in Texas back. They seemed to be very understanding and most likely if it was a short time, they would redo the module again. If you removed the unit then you know it's very simple to take out. Maybe a fifteen minute job at best.
Old Jun 18, 2015 | 11:32 AM
barbsaudi's Avatar
The airbag light stayed off for about a year. Only came back on during first really cold day of the year as Texas shop said it would if not hot-wired. No problem with Texas shop.
pologoped2
Jul 28, 2013 05:47 PM
vtraudt
Jul 15, 2013 08:21 AM
Niclipse
Apr 11, 2011 05:29 AM
MPLSChase
May 5, 2009 04:21 PM
pathak76
Dec 12, 2007 03:35 PM
