ebay vagcom.??!!??
ebay vagcom.??!!??
i just got my ebay vagcom...and i have no idea how to install it and have it work with ross tech vagcom program...keeps telling me that the controller is not working and that it is not registered..
RE: ebay vagcom.??!!??
Download this - http://www.ftdichip.com/Drivers/CDM/...%202.00.00.zip
found here http://www.ftdichip.com/Drivers/VCP.htm
Follow these directions - http://www.ross-tech.com/vag-com/usb/usb-config.html but instead of going to the vag-com folder go to the folder that you extracted from the .zip file above.
who did you buy the cable from? - how are you using it? - do you have the car on(accessory possition or running) are you testing it in the car? or just plugged into the laptop? does the small light on the top of the OBDII connection light up?
bought it from shzid..from hong kong....when i plug in the usb into my computer it tells me to install..so i installed it like it says, followed the instructions exactly. found that it installed on com4..then i tried the test without it connected to the car..doesnt want to find it..when i plug it in..it finds it....then i try to autoscan for codes it says its not the registered version..then i try to go into comfort/conv..tried to do the autowindow with key...then it says that the controller isnt responding....when i autoscan it only works one the engine and one more..then stops.. i dunno what im doing wrong...also a cd came with the cable..and i was browsing around it and found some REVOFLASHII...revotechnik2003...i opened it and it looks like a tuning prog..(could it be an older version of REVO??)
.oh yeah..car is on..ON not running.and light is on from the cable..
to check codes with the unregistered version you need to go into each controler and select fault codes. Only thing I can say about the controler not responding is that the cable might be bad - I got mine from Alpha-bid, The first one that I purchased was from Autonostics and it would not read the car when it was running, could be a similar thing - also are you using 409 or 311 - might want to try 311 - thats what I run.
I think this is the one that others here were having problems with also. Alpha-Bid http://stores.ebay.com/alpha-bidis known to work with all versions of Vag-Com except for the latest version.
