VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Help with Vagcom connection
Old Jul 31, 2006 | 03:22 PM
mypreludeisred's Avatar
Default Help with Vagcom connection
Hey
I have a generic, ebay, jem-auto, vag com cable. I bought it to reset some lights such as inspection 1 ect.
I have the
311.2 shareware software from ross-tech.
Once you start it tells you to :
Go to options, click the right com port, and save it.
No com ports appear to be right as i get " Com port status: inaccesable" After pressing test on each of the ports.
ANy clues here. I did install the correct drivers, At least i believe i did. I located and downlaoded them on the ross-tech site.
Thanks a lot and any help would be appriciated before i rip this cord in half.
Old Jul 31, 2006 | 03:26 PM
techbod's Avatar
Default RE: Help with Vagcom connection
what type of cable is going to the computer?? USB or serial
Old Jul 31, 2006 | 04:42 PM
dafrazi's Avatar
Download the 4XX version of Vag-COM. (I can't remember the actual number but it starts with 4)
Open Windows Device manager.
Look for the the name of your cable; Double click on it.
Read the port that was assigned to it. If it is not assigned to COM 1, 2 , 3, or 4, use the device manager and assign it to one of those ports.
Go back to VAG-COM and test that port.
Make sure the key is in the "on" position before you test the connection.
Old Jul 31, 2006 | 05:05 PM
onepoint8tee's Avatar
Windows control pannel-
System-
Hardware-
Device Manager-
Ports (COM &LPT)
Go into the port settings and open and make sure the port/com you are tying to use with vag matches up.
Old Jul 31, 2006 | 05:45 PM
Ponch's Avatar
I've heard everyone chatting about reVAG'ing thier systems and to be honest, never really knew what you were talking about. Thanks to thins post, I now do and want one of these cables ... any idea on how much I should pay for one? I own an 06 A4 B7.
Old Jul 31, 2006 | 05:47 PM
techbod's Avatar
Default RE: Help with Vag com connection
don't buy of eBay the software is very limited without the licence buy from Ross tech
Old Jul 31, 2006 | 06:08 PM
Ponch's Avatar
Thanks Avant. Is there a model number I should look for? I'll check thier web site assuming they have one.
Old Jul 31, 2006 | 06:12 PM
techbod's Avatar
just give them the data of your car age/ engine/ chassis that sort of thing and they will be only too happy to assist you.
http://www.ross-tech.com/vag-com/index.html
Old Jul 31, 2006 | 06:15 PM
Ponch's Avatar
VAG-COM License with HEX-USB+CAN Interface
VAG-COM License with KEY-USB Interface
What would you recommend for my car and a beginner tunner like myself?
I think it calls for the CAN interface since my car is newer on the website, but I might be wrong ...
Not cheap either! WOW
Old Jul 31, 2006 | 06:23 PM
techbod's Avatar
the first one because it covers CAN, the second one is for the pre 2001 cars but the first one works with both
